E85 submersible hose
2 reading
18K views 49 replies 12 participants last post by  Orangeblastn-byu
#1 ·
I can't seem to find much on anything that states or has been proven to be submersible safe with e85 intank.what are some of you guys running for sub-hose?thanks for your input
#2 ·
I use a steel braided teflon hose. I get it local from a hose manufacturer. But it can be found online also, search Braided Teflon (PTFE) Hose. Teflon is compatible with everything, and well stainless is stainless so its good, tough stuff. Other wise I used to use the $22 a foot, only sold in foot lengths gates shit. Not worth it for me.
#27 · (Edited)
What pump set up are you using that you need 1/2 hose?
BTW this is straight from gates website. I dont know what gates website you are looking at. They wouldnt call it submersible hose if it wasnt.....:
Specially Engineered to be Submersible
Gates submersible fuel line hose contains a special compound referred to as Fluoroelastomer (FKM) which is highly resistant to fuel permeation and hose degredation through the aging process. The high strength Aramid fibre cord reinforcement offers increased burst strength.
It is this advanced construction that allows Gates submersible fuel line hose to exceed the SAE 30R10 rating, which is the standard for submersible fuel line hose application. It also makes the Gates submersible fuel line hose the perfect hose for submersible in-tank applications.
Key Features and Benefits
Engineered for constant contact with fuel (and other liquid petroleum distillates) on the inside and the outside.
Meets the SAE 30R10 specification for submersible fuel line hose applications.
Fluoroelastomer (FKM) construction of the outer cover resists fuel permeation and retards aging.
Aramid fibre cord reinforcement offers higher working pressures and increased burst strength.
Suitable for use with E85 ethanol blended fuels.
#35 ·
Not to be smart azz. But it's submersible hose. If it say suitable for use with e85 blended fuels don't you think that mean it can be submerged in it?
I do.
Sent from AutoGuide.com App
#41 ·
If you're being a stickler...
"This hose is NHRA approved, however it is not recommended for fuel line use."
I just replaced all my summit hose. From front to back, it was cracked and dried out from e85. It's garage kept, so any exposed line wasn't introduced to varying weather.
