If you are having an issue with the Profec B Spec 2 where it surges if you don't cycle it between hi/lo or make a setting change then read what I sent to greddy and the reply below. Not sure if Greddy really wants me to post this, but I know of a few people that are experiencing the issue. The guy I spoke to said the fix should be posted on there website soon. He was very helpful.
Oh and if you want the alarm to come on at 16psi, set it to 230. The issue is there is a conversion problem from kpa to psi.
What I sent to Greddy:
I have a PRofec B spec II, which I got for Christmas. There seems to be a glitch in the unit. If I do not cycle between hi/lo the unit will alarm and surge when I get to 14-15psi. IF I DO cycle between hi/lo the unit will work rock solid until I power off the car. I am aware of 2 other people that are having the same issue. Everyone else I have talked to doesn't have this issue. Was there a bad batch of units?
Thanks,
Chris
Greddy Reply:
I have heard of this problem with a couple of users. However, before I have you send the unit back to us, I would like you to try a few different settings on the B-Spec 2. So if you get a chance, call in to 949-588-8300 and ask for Matt. I would like to speak with you directly.
Thanks,
Chris
Greddy Reply:
