Dcr twin setup wiring
1.1K views 9 replies 3 participants last post by  wommpsssh
#1 ·
I am running the dcr twin Bosch 044 setup. I have already done the standard 10 gauge rewire with a 12v 30amp relay. Would this rewire be sufficient to power the two pumps?
#5 ·
because you're running two pumps off the same power feed instead of one. If you want to use a 30amp relay, you're gonna wanna use a power feed and relay for each pump, but they arent wired from DCR to even be able to do that.
I think the amp draw of one pump is around 20amps, so two pumps would be 40amps....even if the relay did work, why would you want to run the relay at the edge of what it's designed for when it will likely fail and burn out and let you sitting somewhere???
If you got the money to install a twin 044 setup, then having a good, decent electrial system for it shouldn't even become a question.
#9 ·
I dont know about finding it at a local auto parts store because it's not your typical relay...here's a link for one that should work....
80 / 60 Amp Relay - 1 Relay
And for the fuse, just do a google search for '50 Amp Maxi Fuse'...something should come up that you can use.
