2003 Dodge neon SRT-4 - 190,000 miles. 2 weeks ago my car was running fine, and then I shut it off at my house, 2 hours later I get into the car and try to start it and it cranked and cranked but it wouldn't turn over. I went back into the house and waited for a couple hours, I came back out and tried to start the car and it started right back up. Two days later I shut the car off for about 20 minutes, then tried to start it back in the same thing happened. It would crank and crank and crank but it wouldn't start. So I decided to try and push start it, and it worked! Well then I came home shut the car off, and tried to start it the next day and it wouldn't start. I had some starting fluid and decided to try that. The car started right up. But the next day the car wouldn't start again, so I tried the starting fluid and it tried to start for a moment, but then wouldn't start. Now every time I try to start the car it won't start at all. I replaced the ignition coil, wires, and spark plugs and still no headway. I checked the relays under the hood. I switched the horn and the fuel pump relay and still nothing. Where should I go from here? And how should I go about it? I have a voltimeter, and most of the sockets and extensions that I may need as far as tools wise. I don't have a lot of money so taking it to a mechanic or the dealership is out of the question. I also have an AeroForce interceptor scan gauge but there are no codes showing.
