1 - 13 of 13 Posts
at 1st i had it way to far and i was boosting off the gauge ...like ridiculous amount then i turned it down and wasnt boosin more than like 2 psi and now im boostin like 5 and i feel sooo slow ....oh well im just gonna keep messing with it until i get :buah:
Because a small amount of the boost is being released through the "bleed" it requires more boost than normally needed to activate the WGA. Therefore you hold higher boost levels.
You might not NEED a bleed for it to work. It worked well with no BC just hooked to the
stock Green line for a while till I got my new BC in.
Try it with no Bleed and see what happens, if anything just add it afterwords.
1 - 13 of 13 Posts
