1 - 3 of 3 Posts
went to drive the srt4 last night and when i turned it on had a solid misfire, it then died. i went to start it again and same thing, fast forward 1 day and i went to see if anything changed, now wont start, or will barely and then almost boggs down from idle to 0 rpm's, Any ideas? im getting no CEL and have new igniton plugs wires coil
Idle control valve?
any help appreciated
sorry no one jumped on this to give you a reply to try to help.
Did you get this figured out?
Issues like this are pretty hard to help diagnose over the internet. If you haven't figured it out, let me know and i'll give some ideas on what to look in to.
I haven't had this problem with my SRT-4, but with the 80's turbo Dodges this kind of think could be the MAP sensor or the ignition pickup (similar function to the cam sensor on the SRT). You might try unplugging the MAP sensor and see if it changes the behavior. Easy to try, anyway. It's odd that no codes are set, though. Is it possible your gas is contaminated?
1 - 3 of 3 Posts
