ok fine...
anyways the ones you need for the apexi... TPS, Speed and RPM.
the tps is the middle wire of the white connector across from the cable for the throttle body. the easiest way to get the speed sensor is to take out the airbox. ontop of the transmission you'll find a small split loom leading to a big one. look inside the small one, you should find 4 wires, one is a white wire with orange stripe. thats the speed. for RPM i used the cam sensor instead of the crank sensor (easier to get to) the connector for it is on the right side of the cam. i forget which wire # it is but its the mostly yellow wire. just make sure to set the apexi for 8 cylinders and it will read the correct rpm.
