WIREING DIFFRENCES between:Apex-i AFC II & Apex-i NEO
614 Views 1 Reply 2 Participants Last post by  Spaceman
DIFFERNCES bettween Apex-i AFCII & the new Apex-i NEO
The wire designation is for the most part the same here are the diffrences on the NEO:
PURPLE wire is NOT for knock sensor that was done away with and is now for V-Tec in, so we dont need it.
BLUE wire is NOT for o2 sensor anymore it is NOT used as it is a airflow sig input 2 for RB26DETT (nissan) motors.
There is a total of 15 wires on the Apex-i NEO a few more than the old AFC2.
The other wires you will NOT need for the Neon are:
BROWN/WHITE -karmen sig.
BLACK/WHITE- karmen sig.
LIGHT GREEN- v-tec vtm
PINK- v-tec out
____________________________________________________________
The ORANGE wire is for the illumination, you can hook up to a 12v wire that has power only when the lights are on so display dims at night. Its not manditory to hook this one up but may be a good idea to you.
Lastly the RED wire has a new buddy a RED/WHITE wire they both get hooked to IGN. POWER.
The rest will follow the How To in this forum:
GREEN-RPM
GRAY-THROTTLE
BROWN-GROUND remember this wire 1in. closer to PCM than black wire!!
BLACK-GROUND
WHITE-AIRFLOW AND PRESSURE SIGNAL INPUT(MAP)
YELLOW-AIRFLOW AND PRESSURE SIGNAL OUTPUT(MAP)
1 - 2 of 2 Posts
which wire in the PCM or engine bay can I hook the illumination wire to?
1 - 2 of 2 Posts
