1 - 20 of 22 Posts
running 17 wheels with 225/45/17 tires...
when i have even 1 passenger, and take a hard turn, the tire rubs... when i have 3 other people in the car, it will rub on every small turn..
mopar coilovers are not that low if left to the stop ring.. what gives?
-- also run 2 filled motor mounts from deyeme racing (tranny mount is stock though) if that has anything else to add to the equation
was thinking of buying tires 225/40, but that would offset the speedo etc..
let me know what else it could be, i dont like the rubbing :crybaby:
i was hoping against having to get it aligned again... but if just rolling the fenders doesnt do it, then i will.. more - camber then
thanks man :thumbsup:
funny some people with eibachs (lower then mine) dont rub.. oh well, im sure its on my part that needs to be corrected
Freak said:
i thought you were the guy in your sig, yella shirt. perhaps that would explain it..lmao
:rofl: :rofl: :rofl: :rofl:
Discussion Starter · #10 ·
had it with my last wheels, which were exel daytonas... they were a different offset then current 42 wheels
ooo... after that statement, I'm re-thinking the 225/45/17s I was gonna get for my R/T that has Mopar Stage 2 CO's...lowered at the stop ring... shoooot... :-(
zephrus21 said:
you need a 40mm offset to get good clearence on a 7" rim with mopar coilovers.
No to hijack, but, I'm gonna take my kit off (rejoice) and lower it more... but I've got 17 x 7.5" and I *THINK* 35 mm offset, they stick out like mofo's... this is gonna be bad, isn't it? (the rubbin issue) :-( :-( (my smilies dont load/work for some reason) oh man....
Hmmmm.I have the stage 3 coilovers set at their stock height,all 3 filled mounts from Deyeme Racing,using 225/50/16 while autoxing and my tires don't rub.Maybe your tires are rubbing because of body roll.Have you upgraded the sway bars?I did,with a 26mm front and 22mm rear.My wheels have a 38 offset,btw.
Discussion Starter · #16 ·
yea, must be offset then??
Janet, my car wont rub, when im by myself.. its the extra weight of even a single passenger that makes it rub...
Discussion Starter · #17 ·
starkie, you have 42 offset wheels too! and the same setup, hey i didnt know...
please take your wife out for a quick spin and see if that makes it rub in the slightest... on some good quick turns
let me know if possible.. and get back to me!! thanks
Discussion Starter · #18 ·
my camber is prob off... it was aligned to spec when the CO were installed...
i'll ride with you :thumbsup: ... not many want to ride with me LOL
i think it rubs in the front.. you see and outline on the front tires, very noticable..
and tex doesnt work at speed merchant anymore, i heard he went back to school..
1 - 20 of 22 Posts
