1 - 20 of 64 Posts
Hey,
Hoping to get some good feedback.
Car is a stage 3 with all the normal bolt on's.. has run a best of 11.43 @ 125.74... looking for a bit more. Car will still be a daily driver and want it to have a chance at passing an emissions test.
Who's head should i go with? What kind of gains can I expect?
Thanks in advance.
dcr pro sseries. i just ordered the pro series head, and along with a realtune external wga manifold, aem ems, and will likely be using a stroker motor.
JMB Performace sells ported heads with bigger valves in them and i think they said you can see gains of 25-35 hp andi think thats with stock cams but not for sure on that but its the cheapest pnp head with bigger valves i have found yet i am in the process of saving money for there ported head i also talked to another guy that bought one from them and said it was a very nice head and very well worth the money
prety sure I read some where dcr's head can see gains up to 100hp, not sure on that though.......I would call DCR first though and then everyone else, performance wise they are the best, price wise........
DCR pro series for sure. I have some crane 16's f/s if you want them
i have crane 16's in mine as well, run those for your stage 3 set up, there great, nice lope and tons of top end,
With the Nov. discount you can save big on our DCR Pro Series Head :eveilgrin .
Pm me for your discount :thumbsup: .
Later
Discussion Starter #8
Later
Isn't the pro series too much for a DAILY DRIVER?
Is a pro series worth it when you leave the bottom end alone, shooting for sub 400hp levels? What about sending his stage 3 components in to get worked over?
BTW lope is not what keeps your emissions legal by any means. The 16's sound badass but "badass" makes you quite the attention whore. I got pulled over by 2 motorcycle cops who SMELLED my car, and i had a high flow 3" cat on my car. :(
Not at all...all of our cylinder heads are true performers and all are intended for street, strip, road coarse etc. All of our customers are street driven SRT-4s and most choose the DCR Pro Series :eveilgrin !
If you want the best.... we have it :readclose
Later
Retired Member
To the original poster almost a year and a 1/2 ago i went with Darrell's lowest option head, crane 16's new rods/pistons and his modification to the Stage 3R turbo. I picked up over 45hp at 6500 RPM. A Dyno Graph is in my signature.
Street ability was still stock like.
Again that was a much less potent Head then his full race head that he offers now.
You won't be disappointed.
Discussion Starter #13
Thanks for the good info.
Discussion Starter #14
Later
Will this head be okay using the stock cams?
DCR, how accurate is this? What else would be needed for this to be true?
you might gain 100 whp if your on 37r using a stock head, probably depends on what turbo your using, if you had stage 3, im sure thrwoing on a dcr head, your not going to gain 100 whp, i made 421 with my stage 3 set up and i doub tim gonna get 521 out of it, i would be lucky to get 450whp
Thats right James, lowest option head as compared to the next levels DCR Race Head and DCR Pro Series Head :eveilgrin .
Thanks:thumbsup:
Retired Member
Maybe not 100 peek horse power, but on a 550hp car, or any EMS car pushing past 6500 RPM I would say your defenetly going to pick up close to 100hp in the higher RPM's
I would defenetly be willing to bet Kevin Van Natten's Red Sled picked up closer to 200 HP at 8300 RPM between his Full Race Head and Cams :readclose
Discussion Starter #19
Thanks:thumbsup:
How is the low to mid range going to be with the pro series head? Will it suffer?
Thanks:thumbsup:
It picks up from off idle to whatever rpm you can generate. Its slight increases on the bottom but gradually builds all the way across the rpm range. Total gains is dependant on each build, mods, and proper tuning.
Thanks:thumbsup:
1 - 20 of 64 Posts
