1 - 20 of 30 Posts
How do you tune a stock SRT?
depends on the dyno. anywhere from 215-235 i think.
I guess you could put a wideband and a map clamp and lean it out some and make a bit more power but not 260 or 280 but then again that would not be stock.
hay guys my stoc srt4 put down 394rwhp with only 5" tailpipes and a smaller turbocharger so it can spool up faster but i couldn't adjust my incabin wastegate otherwise it would have been teh fastar kthxbye:thumbsup: :thumbsup: :thumbsup:
So what I heard was true! YOU'RE THAT GUY!!!!!:readclose :rofl:
Yep, that's me! I am thinking about skipping putting in my dtech gas controller thingie...I think I am just going to put a carburetor on instead of fuel injection so it is easier to tune up. Then after that I want to take the stock NoS system off because I think air is going in there when it's not on and it's causing me a booooost leak:thumbsup:
its would be alot easier if your incabin wastegate would have an incabin dump :rofl:
:intrestin :intrestin :intrestin why didn't I think of that! Do you think if I boost enough I can light my cigarettes with it? That would be neat!
mattmoto441 said:
Whats the most HP a stock SRT 4 has been seen at ?? i have heard that Stock SRTs with a good dyno tune you put down 260-280fwhp
You didn't hear anything...
Forum Moderator, 2011 Calendar Car
yes you can do that no problem. we do that with our 85 lebaron convertible
I think a local here put down 238whp stock. Thats the most I ever saw
^^^ that was me :)
and whoever said put a mapclamp on it and lean it out.. then um it wouldent be stock. read before typing. thank you.
Jmhm17 said:
^^^ that was me :)
I was hoping you would chime in buddy :thumbsup:
then it would not be stock now would it.
leak check and fix your leaks is about the only thing you can do and it remain stock.
Then you will put down what the factory says you will.
tim ware are my injektahs guy????
1 - 20 of 30 Posts
