1 - 9 of 9 Posts
As some of you know, my car came with the nastiest hooked up gauge pod that was twistied tied onto my pillar. I get sick of looking at its ghetto'ness, so I finally ordered a nice replacement pillar from Modern. Got it in the mail this afternoon. :clap: Well, I had my old ghetto pod taken apart and I noticed the gauges can only go in 1 way, and thats from the outside, because the face of the gauge has a lip on it.
Why in the hell couldn't that lip on the face of the gauge be removeable, so THEN I could just remove the ghetto pod and put my old gauges in my new pod with ease.
But nooooooooooo.
Back of my AFR, Looks like I won't be able to take out the wires from the back on this unless I took it apart.
Back of the Oil Pressure gauge. Now this has a ton of wires, but they all seem like they can be disconnected since they are lopped on with nuts.
Heres the back of the unit I am talking about, No idea where the hell the wires go, do I have tot ake my dash out? How?
Heres a pic of my pretty new one along with the A-pillar piece.
I am guessing there is no way around electrical work, unless I made a fine cut on my new pod under each "boob" and pushed those mo-fo's in and glued it NICELY back together. I will probably go the electrical way, so how in the hell do I get to those damn wires, can I just cut the big bulk of wires and soder them all back together? How do I go about doing this, any help would be GREATLY appreciated.
thanks.
Damn, that is pretty ghetto'd up. There are way too many wires there.
The gauges should have one wire from the sensor (or a 2 wire connector like your oil gauge), a ground, and 1 or 2 power leads (possible 1 constant power and one switched power).
Contact the gauge manufacturer and see if they can send you some install instructions. Personally, I'd rip out all that wiring - except for the ones that run through the firewall and connect to the oil sending unit and afr sensor.
Well the AFR doesn't work, When I bought it he wsaid I needed to weld an 02 bung on the sensor or some shit, so its constantly reading "Lean" when I turn the car on. The oil pressure on the other hand works fine. They are both regular autometer lites. I just absolutely hate dealing with wires because I have no clue where to start. :flame:
take the wires off, take the guages off, put the guages in hte new one then put the wires back on...how hard is that
if your afr gauge is reading lean all the time and he never had the bung welded into the downpipe yhan i would guess you have a hot O2 sensor hanging under your car somwhere beter get that hooked up or its gonna fuck up the sensor $$$
For the bung does it need to be stainless or aluminum? I got a pretty flashy light a/f for christmas.. its not wideband but it will fill the hole (insert pun here) nicely till I do eventually get a wideband.. so now I need a bung just like you welded somewhere and need to know if its stainless or aluminum...
Like someone else already said. Typically wiring guages is a pretty straight forward task. Typically the power is red, black is ground and on mine white and/or blue is the sensor. If you have a volt meter, check the wires out before you take them off. Also, I would invest in a nice solder gun when you put it back together. Way worth the money. I used to just use electrical tape, and I can't tell you how many times I had to take things back apart to fix a loose wire.
Discussion Starter · #9 ·
Hmmmm I don't know man, he never said anything about that I will go look under my car tomorrow and see if I see anything hanging, :lol: I doubt it though... I tried hooking it up this afternoon, mission failed. I will take it apart another day and try it again. Thanks for the responses
1 - 9 of 9 Posts
