Like the title says which ones should I be logging.
I can't find that parameter on the handheld....
INJECTOR--->
AVG TOTAL WORKING PW
80% of all parameters(there's close to 200) are NOT in the handheld. PC requiredI can't find that parameter on the handheld![]()
Thanks, i will try it with my laptop80% of all parameters(there's close to 200) are NOT in the handheld. PC required
so if we wanted to watch more parameters a laptop would be best?80% of all parameters(there's close to 200) are NOT in the handheld. PC required
last time i check with brain on this that feature is not available to us. why what size wheel and tires are on your car now I can check if the speedo is off.quick question...maybe i keep passing it, but where do you go to adjust the tire size through the DS?
ahhh that would explain, i'm on the stock rims right now, with 225/45 tireslast time i check with brain on this that feature is not available to us. why what size wheel and tires are on your car now I can check if the speedo is off.
I have my DS hooked to the computer and I cant find where to go in and look or change anything. just get tune, send to tool, and add tune. any tips?80% of all parameters(there's close to 200) are NOT in the handheld. PC required
Ok, I understand. How can you tell the handheld to log those parameters since you cant highlight them? Or does it just do it automaticly then you use the computer to look at them?.
What duster was saying is that the majority of the PID's that you datalog can only viewed on the computer and not the handheld.
