How does this little gadget give you so much horsepower? Is it safe for the engine and is it hard to install if you don't know how to work on a turbo?
Then watch your boost gauge. :wink:Second Chance said:Turn the dial.
You just adjust the dial to your desired psi (not highr than 16.5psi) and that's it. You should start out by closing the controller, and then adjusting it it a little. Do a test run, see what psi you are getting. Repeat until you are at your desired boost.PsychoMedic said:So its only $129 and it has no electronics? How do you dial in the amount of boost you want?
Lets say I want 15psi. Does that mean everytime I step on the gas I get 15 psi? How exactly does it work?
