Been chasing coolant bleed issue for a couple of days, where my 04 with 174,xxx (155,155,151,155) comp test yieldings, seems to be giving me a hard time with bleeding. Its like my overflow isnt properly toping off the engine and naturally bleeding.
2k miles ago I replaced timing belt, water pump, every bearing and belt + alt, while I was there, all engine mounts with some torquey solutions, full complete silicone coolant hose installed, turbo doesnt leak or smoke, not loosing oil at all. Runs actually phenomenal!
I replaced the following items: OEM overflow, Motorad thermostat 195*, and OEM mopar radiator cap just a few days ago. Bleed all the air out with heater on. (Or so I thought) checked it this morning after putting on 50-100miles of fun last night, and I was missing a little coolant from under my cap. But my overflow is literally at full >.> before installing thermostat which I suspect is working just fine with no leaks in the entire engine bay, perhaps the fill tubes go bad and dont all proper fluid flow from overflow to coolant system?
