what all tools will i needs to put on my springs i have and 05 acr? i would like to know befor i start thanks
If you have and Autozone around they have a nice set of spring compressers for under $40. If you have the means, I highly recommend picking them up.
You need the following....
Spring Compressors,
13mm for nuts that hold the struts in place thru the body of the car
19mm for the knuckle nuts
Hammer to back out the knuckle bolts
10mm to hold the strut rod
and a 22mm o2 sensor socket with a crows foot to remove the top hat nut
14mm and 15mm to remove the rear sway bar endlinks
I think that should cover it... good luck
