1 - 3 of 3 Posts
I damaged the ends on my stock vacuum lines, the green and the black when taking them off to install my AGP wastegate. I just ordered stage 2 and I want to put the vacuum lines back to stock so my toys bezal works. Can I just run regular black rubber vacuum lines in thier place??
yes you can do that. i have all of my "hard plastic" lines out and cut the ends off of all of them and replaced with rubber lines/hoses. i would suggest that you definitely zip tie everything and DEFINITELY do a boost leak check after. youre going to be making lots of more spots to have boost leaks. on the flip side now it's easier to "custom mount" the noids if you wanted to because the rubber hose is flexible compared to the stock lines.
so completely ditch them? or did you just make new ends for them, I'm not really understanding you
1 - 3 of 3 Posts
