What clamp is this?
337 Views 3 Replies 4 Participants Last post by  SafetyNatE88
Some previous owner used a clamp improperly and put a nut through it. You can see the one on the right is proper and the one on the left is improper. I want to get a new clamp because I suspect the improper one could be causing a vacuum/boost leak. Does anyone know what kind of clamp this is and where I get one?
Automotive tire Motor vehicle Gas Auto part Machine
T Bolt Clamps
  • Like
  • Helpful
Reactions: 3
Sizes for reference
x3 2.50" : Cold side intercooler, throttle Body, and hot side intercooler
Greenline part#: G89-040
x1 2.75" : Connecting the hard pipe from the turbo to the
intercooler soft pipe on the hot side
Greenline part#: G89-044
x1 2.25" : Turbo outlet
Greenline part#: G89-036
  • Like
Reactions: 2
vacuum leak is usually only from throttle body to the engine.
turbo to throttle body is normally ambient air pressure - what ever boost pressure your running and doesnt really see much of a vacuum
