threw this today during my map clamp, and fpr mod install. i turn it on , and right away i throw that code, i have no idea why??, i didnt touch the o2 sensor. its o2 sensor voltage too high. what does this, and what do u use to fix it?
P0132-O2 SENSOR 1/1 VOLTAGE HIGH
When Monitored: The engine running for 119 seconds. O2 Sensor Heater Temperature is greater than 350°C (662°F). Battery voltage greater than 10.99 volts.
Set Condition: The Oxygen Sensor voltage is above 3.9902 volts. Two trip fault.
Possible Causes
O2 Sensor Voltage Above 3.7 Volts
O2 Sensor Signal Circuit Shorted To Voltage
O2 Sensor Return Circuit Shorted To Voltage
O2 Sensor
O2 Sensor Signal Circuit Open
O2 Sensor Return Circuit Open
Pcm
so what does that mean, and how do i fix this.
