i need to know the coding of the ignition wires .. so i can finish hooking up my tt..
the wires are all hooked up at the ecu .. and the unit is installed ..the voltage meter works, as does the 02 sensor , and the a/f ratio .. i just need to know two wires at the ignition harness after the sentry key ..
there are four
a yellow/purple
a blue/white
a black/green
and a light red one which im assuming is the constant ..+12v
i need to know which color is the ig1 output
and which color is the ig2 output
there are four
a yellow/purple
a blue/white
a black/green
