1 - 20 of 23 Posts
AGP?
Forge?
Kinetics?
S2?
I have the AGP WGA, but never installed it. Debating about putting it on the car bc of the PTB issues I ve been hearing about.
AGP
No matter which one you use you will have PTB, it is the nature of the tiny stock turbo. It is really not a big deal if you learn to not have a heavy foot lol which is harder for some than others.
Mike
S2
I bought a used S2 because I heard you get a bit less PTB.
I am going to be running stock lines so it should just hold a bit better til redline without much for PTB.
I will be installing it in the next month or 2. Wish I could tell you how it works but won't know for a bit!
I saw the little PTB how to w/ the agp wga in the how to forum. Im gonna try that.. if it doesnt do any improvement, Im gonna have to figure something out. As much as I love the power and all - I want drivability as it s my daily driver!
I just bought a kinetic WGA. I switched to that from an old style AGP. I actually like it better. Just seems to be more solid, and i don't have to have it set up so tight.
What WGA??? I only have two Turbosmart wg solenoids. :thumbsup:
Really, you can either run a dual stage manual or electronic boost control, or do one of those ptb mod someone did on these forums? Lower your plug gaps and change your driving style.
dont buy any aftermarket wga's. i had the agp wga billet style for the last year and sold it for almost as much as i bought it for. i then got the upgraded spring for the stocker and did the dual stage automatic boost controller with the needswings in cabin mbc and it is great. drives just like stock with no ptb issues at all. stock boost in first gear so you get great traction and then in 2nd and up you can just smash it to the floor and hit whatever you have your mbc set at. and with the needswings its nice being able to do that from in the car while you drive down the road. just my .02.
Do yall think the AGP WGA is the best one to get or other????
I just installed the Kinetic WGA. I am impressed, but first time I took it out I didn't realize how high I hat it set to. I slammed on the gas and the needle went way past 20, on it's way around to vacuum. I was like WHOA! Let's not do that again. It is too late now for me to change and test it, so I will just wait until morning, and I will be at it again. I have heard great things abought this WGA, but I will let you know as soon as I get everything set up how I want it.
AGP here, had no problems with it. Took out all the vacuum lines except the White TIP sensor and this got rid of most of my PTB issues.
kaminarineon said:
Stage 3 WGA :rofl:
x2 but I just purchased the AGP S3 WG I am hoping it will hold boost better then the S3 WG
Kinetics
OMFG Rich, when I tell you something you need to listen homo!
AGP all the way, and stop being a pussy about the PTB. I don't have an issue w/ it at all. If you drive normal you won't have an issue w/ it, if you're gonna punch it might as well floor it. It's all in the way you set your wastegate. If you set it so it's overboosting and you're trying to keep it at the safe boost levels w/ your throttle then PTB will be an issue for ya. But if you set it so when you punch it and it boosts to say 18PSI then PTB won't be an issue.
Good luck w/ the project ;)
Discussion Starter #19
hey neven
as I told ya on neoncanada :ninja: Im just doing my fucking research before I go w/ any other routes!
but looks like Im going w/ the AGP route since I already bought it. Hahaha
btw, what project? :rockon
1 - 20 of 23 Posts
