Is this normal? I installed both at the same time. It is a AGP WGA and Mopar BOV. I am getting about 12-13 psi of boost with wastegate only. Boost controller is turned completely down. The car stumbles and surges around 1800-2500 rpms. It feels like it is going to die then picks up the pace. I have tried dialing more boost in with the boost controller and the problem still exists. I turned the boost controller completely down until I can get this problem figured out. It is a 2004 stage 0.
should deffinately go get it tuned on a dyno and make sure ur af is running not to rich or lean, but also how many miles cause i think replacing ur spark plugs helps this...
Is it part throttle?
Problems like this are what you get when you go that route. You'll just have to tune until it's acceptable to you.
Yeah it's at part throttle and the car only has 2500 miles on it. Don't think it's the plugs. I imagine it is a little rich. I still get black soot on exhaust tips even with catch can. I have Crane wires, K&N stock replacement, 180 stat, and the other mods listed above. Other than that it is stock.
JCX- Are you saying to adjust on the wga (raise boost) until this problem goes away?
I went ahead and turned the boost up a little on the wga. I will go drive it in a little while and let you know what happens. Please still respond to my post before this one so I can get your opinion. Thanks.
My point was that part throttle surging is a known issue with the aftermarket WGA's, you probably can't get rid of it entirely. I am no expert at tuning them whatsoever so I can't offer specific advice. What you should do is check around to see how other's have setup their WGA successfully.
