1 - 1 of 1 Posts
I'm looking at the weld magnum import 15x8's and I was unsure as to what offset I would need and the largest and best drag radial I could fit on it, I have the factory acr wheels with a225/50r/16 Hoosier DR2 drag radials and I can not get any traction In 3rd gear, I've tried several different things such as raising the rear end of the car up to put more weight on the front tires, I've completely stiffened to by coilovers in the rear and softened them in the front, lowering the tire pressure down to 12 psi and that helped a little but not much... I'm making 633whp and about 585 ft. lb. or torque. On a 60 roll its destroying the tires all the way through third even after driving on them for a while heating them up.
1 - 1 of 1 Posts
