ok i installed a set of AGP hard pipes on my 05 srt-4. i went by AGP the other day because i had a question on the vac lines, and pulling code p1188, after them telling me the code will stay till iget stage one or higher and fixing the vac lines ive come across a new problem. WHen i shift out of gear under boost into a higher gear, between the gears the engine rev's up around 500-1000 rpms above where i was idling. how would one fix this? is it just that i need to harden or soften my BOV ajuster thingy nut? or is it more compicated?
before some one says it, My foot is off the throttle when i begin to shift, do its not my fat lead foot.
thanks in advance
Keyth
a.k.a Clammy
Discussion Starter #2
bump for the morning crew, just to let you all know my srt is at the bar i took a cab home.
Do the RPM's go up while the car is in neutral???
yes the rpms go upo while in neutral, and to he other post. uncapping the red line should fix it? AGP said to plug it into my throttle body as a temparary fix for the code but it didnt work. ill give uncapping it a go. thanks for the input.
Discussion Starter #6
uncapping the red line worked, thanks for the input.
