1 - 9 of 9 Posts
Well I was stranded on the highway with no gears.
One bushing in the transmission side disappeared and didn’t give me any left to right movement.
One bushing in the shifter side broke off. It was a red bushing. Red booger bushings?
Towed the car home and time to replace the bushings.
I don’t see any reviews on DCR bushings?
What does everybody recommend?
146439
146440
Sorry to hear about your bushings! I started producing delrin bushings last year and have currently 500+ sets distributed to the SRT community. If you're interested shoot me a message or you can check out my ebay listing under "RS Autoworks"!
Ive had booger bushings since 2003. If one fails... i'd say $22.00 for 17 years of performance is a good run. Id use them again.
Same here. Only one failure and it was just cracked but not failed totally. Maybe Yellow > Red?
Your set works great! Very affordable set with clips. I lightly added lube on the bushings on the tranny side.
Also lubed the cables, and put some Lucas oil in the mopar short shifter unit.
Adjusted the shifter bolt while in 3rd. It now shifts amazing!
There are two plugs under the middle dash that don’t connect to anything. Anyone know what they are for?
if your car has the viper seats, those are likely for the airbag module for the fat boy seats.
Discussion Starter #7
Yes Viper seats.
I will take pictures just to confirm the module and plugs. Changing out the bushings was an easy job if you don’t plan to reuse any of the old ones that are still good. Removing that battery tray helped ALOT.
I might be weird but I like how the interior looks without the middle console over the shifter. It’s easier to shift too.
Adjusting the shifter bolt made driving the car so much better. 2nd gear for me before was a pain! Now it goes in like butter!
Administrator
some of those connectors could be backlight and neutral interlock for neons with an auto transmission.
This too.
I forgot about those.
1 - 9 of 9 Posts
