1 - 2 of 2 Posts
Which is a better choice for performance?
My current mods: Stg. 1: 3'inch down pipe: Aem short ram: agp waste gate: thats about it as far as boltons go...
I guess i want to know which ofne of these two would drop my 1/4 mile times a bit more? which would you go with...and why.
thanks!
with the mods I listed i dynoed 266hp and 303 torq. if that helps...
water injection with 30% meth, and a mapclamp tune.
that meth willrichen it up & then you can raise a boost a bit & then tune with a mapclamp. Let your mod after that be AFR meter. AEM UEGO... that wya you can tune yourself, on the fly, for the most accurate & recent tunes. Outside temps varry alot so your rune may change from morning to evening. That way - if you are running someone that evening, you can make sure you are at 100% power & safety wise ;)
1 - 2 of 2 Posts
