1 - 13 of 13 Posts
just wondeing were every body tapped into the boost source from, and if I can use my sunroof for the ignition source.
I t'd off the throttle body.
Discussion Starter #7
thanks for all the info does any body know if I can use my sunroof fuse for my ignition source thanks again.
I'm sure you could, I mean, i don't have a sunroof but i'm sure that it only works then the key is turned over right? If so, it's useable.
Only if the fuse you select has the correct amperage rating................
Marion
dansrt4 said:
Tee off the TB it needs to be a good vac signal so its consistant
Even if thats already T'd for my BOV? Do it after the BOV T?
Pull interior fuse box out. in the back find the circuit (A31 I think) that supplies the bus for fuse 6,7,8 It's a black wire with a tracer. This comes hot with the key in run.
I used this to power the relay for my controler/pump. Pole 30 of my relay (which switches to run the pump/controler) originates at a 20 amp fuse I placed in the PDC undr the hood.
It's more work to do it this way. But it's the way to do it.
You will also find a spot for your new relay in the fuse box.
Ahh. OK. Pic's because I've never been good at explaining stuff.
I hope this was of some help. :hi:
1 - 13 of 13 Posts
