The HKS Super Sequential Blow-Off Valve (SSQV) is a dual stage pull type relief valve. Unlike other blow off valves that are push type, the SSQV will not leak under high boost conditions nor under vacuum at idle. Being of a pull type valve structure, the SSQV can not physically leak under any level of boost because boost pressure also keeps the valve closed against its seat.
The SSQV is actuated by pressure alterations only, not by the rate of pressure or vacuum in the line, which ensures a quick valve response and complete closure during idle. On typical blow-off valve designs, a large valve is utilized in order to accommodate high boost / high horsepower applications.
TECH TIP: You will need a kit to bolt this car on your SRT-4. You will need one of the following: ATP Pressure pipe, Perrin charge pipe, or UR pipe kit (sold separately in our store www.turboneonstore.com)
Part # 71004-AK001
Take an ADDITIONAL $15 off our website price!
Enter srtf69 in coupon code box during checkout.
(Deal Good through 12/19/07 - online orders only, not valid with any other coupons)
Click Here - for LOW Price and details
