21 - 38 of 38 Posts
Discussion Starter #21
There is an "E" cover and "S" cover and a ported shroud option on the "S" cover. With a turbo of that size the "S" cover is the choice to go with.
Discussion Starter #23
How much for an "s" cover ported shroud journal bearing kit 6057 turbo? I do not need the exhaust manifold as I already have a tubular mani that works great!
Are you wanting a kit minus the manifold, or just a turbo? It's a little unclear as to what your asking for. PM me the details.
Pricing and options have changed from the last thread on this topic. These have not made the site yet but all info will be here. With the kits Garrett Performance and Precision turbos are available. We have been a dealer for both for 17 years.
Kits include:
ATP cast log exhaust manifold
ATP O2 pipe with wastegate discharge routed into exhaust (doesn't give up power)
ATP vband flange for turbine housing
Studs and nuts to secure turbo to manifold
Tial 38mm wastegate
Turbo (some options below)
T3 turbine housing gasket
Oil drain hose and flange
Oil feed line and fittings (stainless braided, aeroquip fittings)
45* 2" coupler to connect compressor discharge to hot pipe
90* 3" coupler to connect air intake to compressor inlet
Total $ 2,125
The turbo options for the above kit pricing are:
Garrett Performance 50 trim (490 hp potential)
Precision 5557E billet wheel (535 hp potential)
Precision 5857E billet wheel (605 hp potential)
Precision 5862E billet wheel (615 hp potential)
Precision 6057 billet wheel (630 hp potential)
Precision 6262 billet wheel (670 hp potential)
Ball bearing option for Precision turbos add $ 600.
Ported shroud option available for larger Precision turbos.
Garrett GT Series ball bearing turbos:
GT35R add $ 485 to kit price
GT37R add $ 675 to kit price
For ported shroud option on GT turbos add $ 200.
Other turbos are available, so if you don't see one your interested in ask us.
hey scott its chris from north carolina lol man i did not know your kits where that cheap man i met have to get one really soon and your fmic like i said lol
Discussion Starter #28
Any way we could get the precision turbos say with a kit like agp's? I want an external dump.
We can get the turbine housings with a bolt pattern for there O2 pipe or you can make your own external dump with our kit, by blocking off the re-route. Most ended up having us re-route it after a job so we only offer it with the re-route, now.
well i dont want the reroute, would this cost any more to get the turbine housing that would bolt to their o2 pipe? looking to buy a kit real soon so jus trying to weigh out my options...
Discussion Starter #30
No, but if your going with a kit other then ours we will need to know the bolt pattern of the O2 pipe your supplied with.
Supporting Vendor (Gold), SRTotM Moderator
21 - 38 of 38 Posts
