No problem. He used the AGP rather than the Turbochargers wastegate so you might have a different, better experience if you experiment. Personally I figure if you paid all that money for S2 and waited all that time for it to finally arrive, then might as well install it per the instructions and give the PCM a couple days to adjust in order to get a true, accurate first impression. If you're still wondering after that then swap in the other WGA (I would recommend the stock lines) and see if it's an improvment.iupui1299 said:Thanks Steiner.
