Ok... Here's the story.
running 930ct. and no W/I and a .26/.47 nitrous pills the car ran a 13.9 AFR.
Installed W/I with 60% meth and 40% water and a .32 fuel pill. So rich it wouldn't go :stab:
Dropped the fuel pill down again to a .28 and ran race gas and its got a 9.00AFR ( lowest the wideband will read ) with W/I on.
Pulled the W/I off and pulled 18% full from 4000rpms+ and it ran a 11.7AFR dropping to a 10.0 at redline.
Is it possible that the M5 nozzle with 60% meth is adding THAT MUCH FUEL ? Hell, I'm looking at dropping BACK to the original .26/47 pills with the W/I just to get a 10.5 AFR on the bottle...
Possible the M5 nozzle is adding 1.5 worth of AFR to the mix ?
Tuning W/I on the motor = easy
Tuning W/I on the bottle = expensive....
I'm not giving the W/I up, I can't believe how cool the intake stays not !!!
im running a 47/24 combo with a 50/50 mix and that seems to be perfect. try the 24 jet without pulling any fuel and then go from there...
Thanx, your the second person to tell me that... I'm scared, hehe.
Car ran 12.09 with no W/I and .26/.47.. the lean AFR scared me...
I have a upgraded fuel solenoid... Would that any effect on anything ?
I don't have the normal "power shot" solenoid, I have the bigger cheater solenoid... Not sure if that mattered...
shouldnt matter any....but 12.0: is perfect with the water injection!! might be a tad high without it and the stock turbo...but with the water injection 12.1 would be the perfect sweet spot in my opinion
