I have been having the idle air control problem with mine for a while now the car set for 3 years and I have a brand new idle air control valve I had all my vacuum lines redone and we can't figure out what the issue is I have checked the wiring to the idle air control check the sensors TPS and the knock sensor are fine so is my air temp so only thing I can think of is I do have a solenoid delete because I have the HKS blow about in the AGP wastegate I also have a bigger room I do have a wide band and that pretty much it it was just out of shop to have all this done and the owner of the shop has a 05 himself the only codes I'm throwing are the solenoid delete codes I I do have the borla exhaust I can't find any shops that will tune in the car around here is there a plug and play one that I can use
