Yes I searched and no there is not a good review of the current oil catch cans available for our cars.
One review drives the car once every 2 months.....thats not helpful.
Anybody drive the car daily with a fully functioning oil catch can?
Does it need to be a welded unit to not leak on our cars?
Can a ebay screw on unit work with upgraded hoses?
I understand check valves are needed.
Two catch cans better than one?
I'm using an eBay CC with the side 1/4" sight tube along with a McMasterCarr low crack pressure check valve.
The CC needs draining at 10K mile intervals and never leaks. I did drill the two brass 90 degree CC fittings with a larger drill for better flow.
Be sure to use plastic cable zip ties on all hose ends.
Have you checked if your still getting oil in your intake stream?
Will 2 catch cans be more efficient?
One on the intake side and the other on the passenger side?
I have two. The intake side doesn't fill up very much. Before I did it I would get oil spots on the ground coming from make up filter
It seems the BOV is blowing out oil....great....but there are 3 down sides.
1. Its pointing directly onto the PCM
2. It stinks!.....your can smell it while driving and your clothes smells like oil after a little driving.
3. Still getting blow by. At certain RPM pulls...there is a studder.
I
You want the catch can to be the lowest point in the system. I put mine down below the airbox. As for catch cans, you want one that has some baffling inside, not just two barbs next to each other without anything in between.
