IF you chasing that long block record here is an ez way to keep track ....(get inline LOL) if not post up your stock long block times.
as long as you have a stock long block(ie stock pistons, stock rods, stock unported head, stock valves, stock cams etc) post your times here.
Don't matter who tuned you, what turbo you run or if you have nitrous. you are welcome to post mods but you must post a time slip/video,
I found a few of the fastest ones I know.
Don't matter if you run 10s or 15s post them up, order will be in fastest et
Use this template
username
60ft | 1/8 et | 1/8 mph | 1/4 et | 1/4 mph | fuel used | turbo/nitrous
1.) zeroRWHP
1.63 | ???? | ??.?? mph | 10.81 | 132.0 mph | rg | s3 FP green
2.) Tonydsrt4
1.73 | ???? | ??.?? mph | 10.82 | 135.0 mph | rg | BWs256
3.) underSRTarmor
1.70 | 7.18 | 98.29 mph | 10.99 | 132.2 mph | e85 |BWs256
4.) Zenkat
1.81 | 7.34 | 103.1 mph | 11.21 | 127.8 mph | e85 | s3 EF1
5.) karkraft
1.77 | ???? | ????? mph | 11.233 | 128.4 mph | 110 | 50 trim
6.) Bigwiggs83
1.79 | ???? | ????? mph | 11.25 | 131.0 mph | 110 | bws256
7.) kicks
1.81 | 7.43 | 98.83 mph | 11.32 | 130.1 mph | E85 | 50 trim .63
8.) [email protected]
1.78 | ???? | ????? mph | 11.39 | 123.9 mph | 110 | FM 44lb s3
9.) Turbolag87
???? | ???? | ???.?? mph | 11.40 | 125.0 mph | 93 meth | s3 47lbs
10.) Whiteout2011
1.82 | 7.54 | 98.20 mph | 11.48 | 125.4 mph | E85 | 6262dbb 25 psi
11.) all motor
1.82 | 7.52 | 98.03 mph | 11.48 | 125.3 mph | E85 | 3582r
12.) sakibsautoworks
1.67 | 7.34 | 93.61 mph | 11.53 | 117.1 mph | 93 | stock turbo
13.) 1sikACR
1.84 | ???? | ????? mph | 11.54 | 120.0 mph | 110/pump mix | delta 48
Use this template
username
1.) zeroRWHP
2.) Tonydsrt4
3.) underSRTarmor
4.) Zenkat
5.) karkraft
6.) Bigwiggs83
7.) kicks
9.) Turbolag87
10.) Whiteout2011
11.) all motor
13.) 1sikACR
