1 - 1 of 1 Posts
I'll add more when I get more time. Also If anything looks wrong PLEASE CORRECT ME!!!)
Cylinder head bolts
Tighten the cylinder head bolts using the 4 step torque-turn
method, tighten according to the following values:
First: All to 34 N·m (25 ft. lbs.)
Second: All to 68 N·m (50 ft. lbs.)
Third: All to 68 N·m (50 ft. lbs.)
( Don't use torque wrench for forth step)
Fourth: Turn all bolts an additional 1/4 Turn
Camshaft bearing caps
Install right and left camshaft bearing caps
Tighten all smaller caps to 12 N·m (105 in. lbs.) in sequence
Tighten both bigger caps to 28 N·m (250 in. lbs.).
Valve cover
Tighten fasteners in sequence.
Using a 3 step torque method as follows:
Tighten all bolts to 4.5 N·m (40 in. lbs.).
Tighten all bolts to 9.0 N·m (80 in. lbs.).
Tighten all bolts to 12 N·m (105 in. lbs.).
Bedplate bolts
Tighten bolts 10 inner bolts of bed plate twice to 41N·m (30 ft.lbs.) in sequence.
Tighten 10 outter bolts to 28 N·m (250 in. lbs.) in sequence.
Tighten 10 inner bolts again to 75 N·m (55 ft. lbs.) in sequence.
Tighten 10 outter bolts again to 28 N·m (250 in. lbs.) in sequence.
Connecting rods
Tighten the connecting rod bolts using the 2 step torque-turn method.
Tighten the bolts to 27 N·m (20 ft. lbs.).
Tighten the connecting rod bolts an additional 1/4 turn.
1 - 1 of 1 Posts
