I need advise.
My A/F ratio is too rich. The dyno showed 10:1 at about 4k rpms. The dyno I went to only went down to 10. The way the curve was dropping I am going to assume that my car was at about 8:1 at peak HP.
I'd like to try to lean the A/F ratio out a bit. What are my options?
My mods: stage 2, intake, and exhaust.
my car is a stage 2, CAI and mine was about the same as yours droping down to sub 10.1 a/f
you have a few options.
Map clamp, power paq, stand alone fuel system or some other type of piggy back computer
I added a Dasmopar map clamp my car now comes in at around 12.0 and ends at 11.3-11.5
this also added some timing
I am sure others will post about the same info on what you can do.
That sounds great. I was considering a map clamp, but wanted to know what other options I had.
Where can I buy/order the Dasmopar map clamp? Who else sells map clamps?
Thanks for the help!
