1 - 20 of 37 Posts
Like the title says, i hear a ticking/rattling type noise while under full boost in higher rpms coming from engine area. I know its not the boost gauge cause I can here from outside when I have the window down. I'm not sure if its the engine pulling timing, detention or somthing else. maybe its normal. it doesnt happen all the time, just when i really step on it. any ideas guys?
my mods are stage 1, agp wga and other stuff. i'm boosting about 18ish
I Get the same thing, It is a Rattling noise that sounds like it is coming from the Turbo. At full boost I can hear it clearly. Also When I pop the hood I can hear a slight rattling noise coming from the turbo.
The car runs fine though.
Any ideals.
Mean9reenMachine said:
sounds like detonation...do you have a wideband? your a/f ratios may be in the 15's:wah?!: if you are hearing sounds like that under WOT.
Thats what I was thinking. No i dont have a wideband, I know I need one.
Discussion Starter · #8 ·
I used to run 100 octane mixture (1 gallon for every full tank of gas) in my car, but I havent put any in for awhile now. I should put some in and see if the noise goes away.
possibilities
1) exhaust leak
2) valve (lifter bad?)
3) injectors
these would make a "ticking/rattling" noise
If you free rev the engine (not to redline - just a quick blip to maybe 3 k), do you hear this noise, or is it only under load?
its the pin that holds the waste gate arm, it rattles. my buddies does it all the time when he gets on the the throttle pretty hard. see if it is a little loose.
Discussion Starter · #12 ·
TomC3 said:
1) exhaust leak
3) injectors
it will only do it under load, and it dosent do it all the time. seems more noticeable in 3rd gear.
Discussion Starter · #13 ·
i put 1 gallon of 100 octane in when a filled the tank up. Car runs better but still does it. I was mad though 100 octane went up to $6.99 a gallon, before it was $4.99 a gallon. o well. I think I really need a wideband to fix this problem.
Discussion Starter · #15 ·
can you take it to a shop that has a dyno? Just do some baseline runs and see what your a/f's are...
i've been wanting to get on a dyno for about a year now, maybe i'll make it to the st motorsport one coming up. The hot weather and really crapping gas out here in california, is probably why my car is running crappy
Just turn down the boost. When you are able to measure a/f, be it dyno or wideband, you can tune safely.
I agree with everyone, as it could be alot of things. But if you are detonating, you really need to be careful and get a wideband soon. you could really do alot of damage fast. i know you probably already know that but just in case
Take every safety precaution you can.
mine was doing this and i dynoed it and i was mid 13's by 3500 rpms.. lol i cant amagine if i kept going. threw some fule at it and problem whent away.
wow really? :stab: would a stage1 assist w/ fatting that up? well, maybe not in your case... running 12s lol... but...
1 - 20 of 37 Posts
