idk if mines the same problem or not, i have a side-exit exhaust and its cat-less (idk if this is why) but sometimes the throttle sticks at just above 1k rpm WHEN IM PARKED OR AT A RED LIGHT and the exhaust makes a "tuh tuh tuh" noise (creepy and sounds bad), the rpm sometimes stays up in-between shifts and when i put it in neutral while rolling it'll sometimes stay up at 2.5k rpm, and yes i did feel it somewhat pull like in cruise control when letting off of the gas while in gear
im asking if this is the same problem since i havent read about a few of the symptoms i've had in the few pages i read
P.S. my forge bov has a cracked/bad diaphragm and i have a huge boost leak from there (slow psi climb/turbo doesnt hold compression at "spooling" rpm)
