Just baught an SRT 2003. This thing runs but is in bad shape. Whoever messed with it should never TOUCH another car! It's got wires and vacum lines hanging loose everywhere. So one problem at a time. First up the engine is out of a PT and the water lines to the turbo are routed pt style going back through the block the return line is blocked off where it should run into the heater core and instead runs into the block. There is water leaking somewhere either from the rigged turbo lines or possibly a blown head gasket and hitting the exhaust causeing smoke to roll out of the engine bay. Could this be because the PT line is going back into the block and not where it should?
