Installed Tein SS and ST sways.
The ST sways arnt the biggest. actually the front sizes were nearly identical.
The rear was larger though,
heres the setup :
Rear bar is set full soft, ride height is about level (maybe a little lower in the front)
front camber is at 0
rear camber is at -1.5
the rear end slides out on hard turns wildly. its really scary. I took it to an autocross and i could still get severe understeer in the slow turns, but on the fast ones, it was a 4 wheel drift. seemed like the car was balanced good there, but on high speed turns its out of control. If i run more negative camber in the front it will be worse.
what are your suggestions? I am running the stock wheels and tires (kdw) for now (wheels are on the way to run 225s)
i have a track day at NHIS this month and i dont want to die, yet.
im goign to re-align it for the track day, run somethign to the tune of probally -2.5 in the front, and -2 or -1.5 in the back.
the tein ss have the same spring rate in the back as the front, i know this is adding to my problem, perhaps i should upgrade the front spring to say at 350#?
otherwise, you tihnk if i replace all the bushings with urethane/plastic it will make a big difference?
thanks guys.
heres the setup :
thanks guys.
