1 - 7 of 7 Posts
Now through Dec 23 take 20% off all Wilwood pads!
Great stocking stuffers here;
Forged SuperLites
DynaLites
Even some pads for you StopTech guys- Believe we have both E and H for you.
Would you recommend E or D compound (for Dynalite calipers) for a daily driven SRT-4 that goes to a track day once a month? Or should I stick with the Q pads and just switch to E or D before hitting the track?
Thanks.
Depends on the heat and response you want.
The D pad is a great Auto-x pad. Same pad I run in the Pikes Peak car. For cold rotor temps. But I can fade them a bit with too much left foot or turning brake. Excellent for 'right now' braking.
The E pads are the superior pad for modest track use. The upper temp range is better than D and the response is not too bad cold. Better than D for sustained temps.
The BP10 is the newer pad. It is supposed to be the more middle ground and less problematic as Q. (I no longer use Q as I've had way many complaints) Personally I don't feel the BP10 is quite up to the task of either the above pads.
If you're happy with Q and simply need some modest open track parts; E.
If you're happy with Q and simply need some more bite/drags/auto-x; D.
Great. Appreciate the answer. Do you have E pads in stock? This second question may sound stupid (first time I buy replacement pads for the BBK): does the set of pads come with all 4 of them?
Thanks!
1 - 7 of 7 Posts
