· Registered
with the mods in my sig...i actually just put the exhasut on and i havent tested out first gear yet but im assuming its going to be useless...i plan on launchin at like ~ 1800 rpms and hopefully keeping the wheel spin relatively low, looking for mid-low 13s...any advice on like preparation of the car ie. tire pressure, should i grab some new plugs (i still have stock ones), etc anything like that would help...thanks
· Registered
Practice makes perfect as far as launching! I would start launching off idle to get the feel of it. If you are running Street tires make sure you do not lower the pressure past 25 lbs. Do a small..and I mean Small..Dry hop to clean the tires before you stage. No big John Force burnut on street tires! hehe Good luck!
· Registered
don't try to get a low et. you need to get a good 60' the rest is just normal driving. you should be able to get a 2.1-2.2 60' on stock tires
· Registered
you modt certainly can get times like that on the stockers, in my stock o4 my first time out i pulled a 2.2 60'. i feather the clutch some dont reccomend this because it is hard on the clutch, but i ease out on the clutch in on the accel and get good times. lookin for a 2.0-1 tonight
