1 - 7 of 7 Posts
So here's the deal, every time i pull out of a drive way dealership with a slope going onto the road my suspension makes a popping noise. I took it in and they think it's the swaybar links. So my car goes in tomorrow to get fixed. Just wondering if anyone else is having this problem.
From the front or back? If it's from the back, the upper strut mounts are infamously terrible for making a clunking noise. There's not enough rubber to keep the integral metal washer from hitting the plate.
the dealer thinks it's the front, you can feel it under your feet.
if you're on the passenger side it sounds like it's coming from the back, if your driving it feels like it's popping through the floor board.
just got mine back from mechanics and the case that holds the suspension to the frame was loose. mine shifted a sixth of a inch and cause something to hit something else and they just moved it back and torqued all my bolts down. I also recieved new sway bar links and bushings, and now my car handles better now than it did when i bought brand new. Seems the car's suspension bolts didn't come tight enough from the factory. if anyone else is having this problem try tightening the bolts and check for movement.
1 - 7 of 7 Posts
