Does the Mopar stage 2 with turbo toys come with a upgraded turbo or does it still use the stock turbo TD04LR?
Stage 2 was a computer, 3-Bar MAP&TIP, WGA, 682cc Injectors and the toys option got you an intercooler sprayer on a timer switch, some LED lights, boost control, 100 octaine switch.Does the Mopar stage 2 with turbo toys come with a upgraded turbo or does it still use the stock turbo TD04LR?
No none of the stage cars are designed to be used on pollution controlled vehicles.Thanks for the info lilviper!![]()
right
exactly what i was thinking and the coolant cap too. I’m going to check the car out this coming Wednesday. If all checks up ok then I’ll be buying it. I wonder if the stage 2 would pass CA emissions?
Damn.. Yeah i kinda figured that. Maybe i can put everything back to stock spec. Not sure how much of a pain that would be.No none of the stage cars are designed to be used on pollution controlled vehicles.
They will not pass Californias commie rules.
Most Californians (That I've ever met) do something highly illegal. They just change to stock, to pass smog at the least reputable place possible, then switch it back until its elsmoggo time again.Damn.. Yeah i kinda figured that. Maybe i can put everything back to stock spec. Not sure how much of a pain that would be.
Or just pay for a crooked smog and call it a day.Most Californians (That I've ever met) do something highly illegal. They just change to stock, to pass smog at the least reputable place possible, then switch it back until its elsmoggo time again.
Other more crafty ones form an LLC in a different state, transfer ownership of the vehicle to the LLC and then plate it in that non-commie state thereby bypassing the smog rules entirely and live life as a slightly more free person.
Others buy teslas and contribute to the downfall of society (you know who you are).
Yup. looks like a stage 2 with toysStock turbo correct?
Again, thank you for your help. 👍🏽Yup. looks like a stage 2 with toys
No, that is an intercooler sprayer.These are all the codes that popped up P0202 P0113 P0073 P0633. I passed on the car but still having second thoughts about it…![]()
id offer 4 grand and see. lotsa unknowns there.No, that is an intercooler sprayer.
willing to bet its been beaten pretty hard.
P0202 #2 injector circuit code. probably a bad injector.
P0113 IAT is disconnected... duh. its not connected..
P0073 Ambient air temp sensor.. duh its not connected.
P0633 is a stage computer, SKIM isnt programmed.. not a real code.
