Anyone running the stock injectors on a S2 setup? If so any issues? Is this ok to do? Any help or advice would be greatly appreciated.
Cheers.
Well once i have the full setup for S2 Im hoping to spike at about 19 and hold 16-17psi if possible?
Administrator
why do you want to run those injectors? so it won't be as rich? safety, running high boost in the summer with small injectors isn't the safest thing to do.
I ran that setup on my 03 for about 8 months before going to a 60 trim. I ran the same boost levels you are wanting to run. I gained about 30 hp and 35 ftlbs by just swapping out my S2 injectors with the S1 injectors. One thing I would recommend before doing this though is to get a wideband O2 gauge. Every car is differant and I would hate for you to blow your motor because I or anyone else said you could run this setup. I dynoed 282hp and 321ftlbs running S2 w/S1 injectors.
