1 - 7 of 7 Posts
Ok, so we have replaced sway bar bushings and endlink bushings. Wheel bearings, tie rod ends (inner and outer) are good, ball joints are good, axles have minimal axiial play, no radial play, rotated tires front to back, replaced powersteering pump and pressure switch, and have AGP upper/lower torque mounts and trans mount. Still got the wobble when you let up on the gas. The wobble is preceded by a double"clunk". All of it was double checked by a couple of mechanics at a local NTB that we trust as well. Any ideas?
Check video New video by Jake Enger
if all that has been replaced and checked, and the alignment was done, the only thing i can think of that would be left to check/replace would be the control arm bushings.
We have the psifi rear bushing (vertical) and the Ragetek delton bushing for the front (horizontal). Both look in good shape, with no unexpected play in them. But will pull them off and check again.
Ever figure it out? Kind of curious.
Discussion Starter #6
no, we thought qwe had it all fixed, we replaced the LCA bushing, ball joints, coilovers, knuckles, and still had the issue. We are currently swapping out the steering rack.
1 - 7 of 7 Posts
