1 - 11 of 11 Posts
What’s up guys been a while since I’ve posted on here. I’m getting ready to install my Stage 3 MOPAR turbo kit with the TurboBays 47lb billet wheel. My question is could I get it all installed and still drive it while I await my tune back from my tuner? (Email tune). Any advice will be greatly appreciated! 💪🏽🙏🏽
I wouldn't. You are currently tuned for your current turbo's airflow. Adding more airflow may cause a dangerously lean condition. Turning down the boost may suffice though.
100% you can.. just don't get into boost..
strongly suggest dumping the injectors and rail and getting a 80# injectors and a tune (duster)
Thank you for the response! I’ve actually got a set of 1025cc injectors and a Boomba fuel rail. That and the custom 450 Johnny Boost Fuel system with custom return and feed lines rated for e85.
car is going to fly. e85 really will wake it up. Definitely do the fuel system right the first time. I was on an unmodified S3 turbo with the 1025cc injectors, 255 drop in fuel pump and the mopar stage 3 rail/fpr and it put down 398whp/399wtq. Injector duty was at its limit due to the pump and the bottleneck. bigger wheel stage 3 on e85 on a healthy motor and proper fuel system with around 27-28lbs should put you close to 450whp+
ditto.. same numbers for me
255 max's out at 400ish.. my 450 has pressure problems (1300's with 58 base, switched to 1500s @43psi), next time i'm going to do a 525 pump
  • Like
Reactions: xrproto07
2004 Eblue SRT-4
Wow man that’s a nice setup! I am loving my BWS 2.0 from TurboBay, it’s well crafted and it sounds really nice. I’d like to get mine on the dyno, very curious about the power it’s putting down.
Discussion Starter · #11 ·
I would be super pumped if I got anywhere in the 400whp+ range man!
1 - 11 of 11 Posts
