Premium Member, 2011 Calendar Car
When I go WOT, the boost just increases to 15psi and holds there. It doesn't spike up like it used to. A few months back I remember it did spike to about 17psi and fall to 15. Did a couple of boost leak checks and nothing. Reset the pcm and still same result. Could my wga be going bad? It's about a year old.
It sounds like you have a small boost leak, it would be an easy check to do, and if you don't have a leak, then I'd consider swapping out to an agp wga or something else :hi:
I do have an FM wga coming so it's not that big of a deal. Just wondering if this has happend to anyone else. Not sure on the life of the s2 wga. Should last more than a year though.
Ever check your car for leaks? Most over look it, including myself, and find out that they in fact have some.
Yes. I check at least every 3 months. And never find any. T-bolt clamps FTW! Last time I checked was 2 weeks ago.
