1 - 13 of 13 Posts
I just want to know if using the Stage Two Wastegate on Stage 0 is fine. A friend of mine is selling his Stage 2 wastegate and i was thinking of buying it. My mods are...Mopar BOV,Mopar STS, and i have a boost controller that i am going to throw on.
i ran the agp wga with stage 0 and no b/c and my boost spikes to 19 and drops to 15 in every gear but 1st. so i dont think you will be hurting any thing. i haven't had any problems with mine .
We are currently running the Stage 2 wastegate on my Eblue 2004 Stage 0 car, boost hits 18 and drops arond 15-16 to redline. We knocked off a couple tenths of a second off of our ET with this wastegate, we do get the occasion overboost code....
Car runs strong...
I think it would definitely be a good idea. Since the stock WGA's spring is too weak, it opens up on the bleed pressure alone. The S2 WGA will ensure that the WG stays closed when it is supposed to stay closed.
Is the wastegate adjustable? and how bad is it if your getting the overboost code on? i Have been tuning a boost controller and the code comes on right away when i boost high. I think i might have some leaks...because when i take off the boost controller i wont hit past 10 PSI.
the wastegate is adjustable and the boost code is easily fixed with the ED Tip sensor mod.....
however, we have not done this mod, we simply reset the PCM and go happily on our way...
We have had the Stage 2 Wastegate in the car for 2 1/2 months and thrown the code twice...
We would be willing to help you install it and adjust it if you like....
We can even try and help troubleshoot for any boost leaks...
1 - 13 of 13 Posts
