First, All PT Stage 1s are are year specific, you cannot put a '04 Stage 1 on a '05,
(as per Flight Systems Research, they are the programmers for the Stage PCMs) and yes the '05 & up Stage 1 has a a little more power than the '04 and back models, this was proven by me and several other '05 and '06 stage 1 cars on the dyno, starting with the '05 the Stage 1, the spec/install sheet shows 235hp to the
wheels, '04 and back show 235hp to the
crank this was confirmed by the Mopar hot line techs and on the dyno, my PT is a '05 DC4 Auto Stick, with Stage 1 Kit w/exhaust, plugs & wires as per the Stage 1 upgrade recommendations for full Stage 1 power levels, it dyno'd several weeks ago at 235whp, 295wtq, there are at least 4 other '05 & up Cars on PT Crew that all dyno'd around 230 to 235whp and 290 tp 315wtq with just a complete Stage 1 upgrade ie.(PCM, exhaust, plugs & wires) no other mods to the boost or WGA, most of the '04 and back Stage 1 only dynos I have seen are in the 177 to 205whp range.
Also all of the above mentioned cars have this 235whp with Automatic transmissions, so I do not know if the 5 speed cars will dyno higher or not, there is an approx 20% loss in the PT Auto trans drive train, so that would be about 280+ hp to the crank for the '05 & up, vs. the 235hp to the crank of the '04 and back Stage 1 PTs.
My Dyno sheet from last month:
http://www.alcamar.com/mods/images/Best Run.JPG
